need to know... Coil and the module.
Old May 31, 2003 | 01:57 PM
yorkie's Avatar
What is the little module thing that attaches to the same bracket as the coil? What does it do, how can you tell when it is bad?
Old May 31, 2003 | 02:22 PM
yorkie's Avatar
It is called a Ignition Module...
what does it do? How do you know when you have a bad one, it takes all the heat off the cylinder head...
Old May 31, 2003 | 03:35 PM
yorkie's Avatar
Its called a EST
Electronic Spark Timing module.
Old May 31, 2003 | 04:14 PM
Do you have multiple personalities?
It is the Ignition Control Module (ICM). It take pulses from the pcm and then signals the coil to fire. Sometimes it can cause a miss when it's electronics are failing with heat. Most times, they just fail. Fail = no spark.
Old May 31, 2003 | 04:17 PM
yorkie's Avatar
ha ha split personalities..
So it is either good or bad, car either runs or wont run basically.
Old May 31, 2003 | 04:21 PM
yorkie's Avatar
I am have detonating, like the motor is running lean bigtime...
I cant figure out what it is?? Have 30 accel injectors which are new, adj fuel pressure regulator set at 46 with hose off. Cat is gutted (which made no difference) Had 4 pcm's from Bryan. On the 1-2 shift and then give it a load it pings like mad. It is a 383 and has -12cc pistons, so I know the CR is like 10.8:1 or so.
Old May 31, 2003 | 04:23 PM
yorkie's Avatar
Also tried a different coil....
made no difference and has new tr55 NGK plugs, wires are new, has a 160 thermostat. I think it is just too lean.
Old May 31, 2003 | 05:02 PM
yorkie's Avatar
I set the adj fuel regulator at...
47 psi with the engine running and vac hose off, like 38 with it on, take it out and WOT it and it reads 44 psi??? Shouldnt it be 47? Is the pump going south? I just put a new fuel filter in too.
Old May 31, 2003 | 08:36 PM
yorkie's Avatar
ttt
ttt
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
