Need help with test questions (tech forum related)
This is a tech related question.
How do you calculate compression ratio?
I missed this class and the teacher briefed me on it but I forgot. He said something about TDC and BDC being subtracted?! He said you also have to count the surface area of the cylinder head combustion chambers when calculating.
I also need to know how to calculate displacement.
Its bore* Stroke and some other crap I don't remember.
Re: Need help with test questions (tech forum related)
displacement = pi/4 x bore^2 x stroke x #of cylinders
-Mindgame
Mindgame has it. He called displacement of one cylinder the "bore vol(ume)". It is also called "swept volume". "piston volume" is dish (+ number) or dome (- number).
Perhaps an understanding of what the compression ratio calculations mean would make it easier to understand the math.
Just memorizing a formula isn't going to help you much if engine building/design, etc. is in your future.
That being said:
Since displacement is so often calculated, here's an easy way to remember how to calculate it:
bore x bore x stroke x number of cylinders x .7854
4.00 x 4.00 x 3.48 x 8 x .7854 = 349.85
or for one cylinder, 4.00 x 4.00 3.48 x .7854 = 43.73
The little square of numbers on your calculator starting in the upper left is 7854. (BTW, PI/4 is .7854 to about 5 decimal places).
No numbers to memorize; just understand what displacement is, and use your calculator.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
