Need help "spark plug removal"
Old Mar 5, 2006 | 11:09 AM
jkucz31's Avatar
im doing the Lt4 valve springs on my car got all of them done except for, i cant get the spark plug out on the first one on the passenger side near the front of the engine. what do i need to take off to get to it thanks......
Old Mar 5, 2006 | 11:35 AM
transAMdriv3r's Avatar
Re: Need help "spark plug removal"
i worked my way up from under the engine and had someone on top put the ratchet on so i can crank it from underneath. thats how i did it and it wasnt so bad, mabe someone has a better way.
Old Mar 5, 2006 | 12:20 PM
2000GTP's Avatar
My favorite plug! I usually put the socket on first and then I connect an extension and a ratchet and I get it from the top.
Old Mar 5, 2006 | 01:02 PM
CamaroBrad's Avatar
I just changed mine this week. What I did was use the socket with a universal and went in from the top. I also removed the altenator to give me some more room.
Old Mar 5, 2006 | 02:35 PM
Scotts94z28's Avatar
Take the alternator off if you havent already.
Old Mar 5, 2006 | 02:54 PM
toegead93's Avatar
Use the special made F-body spark plug socket and a ratchet wrench form the top. Altenator off helps too.
Old Mar 5, 2006 | 10:00 PM
jkucz31's Avatar
its done and time for setting of the valve lash. the spark plug was easy as hell hahhaha knock on wood
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
