CamaroZ28.Com Message Board
-   -   need help with pistons (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/need-help-pistons-319475/)
sskevinm Nov 21, 2004 01:38 PM
I just bought a eagle forged 383 crank with 5.7 "esp" h-beams for floating pin pistons. Now I was looking at SRP 4.030 -16cc inverted dome pistons. I am trying to keep my c/r around stock level and with these on 58cc stock ported/polished head(2.00 I, 1.60E valves) I'll get 10.4:1 c/r. I am looking at making 350-400 h.p.& torque at the flywheel. I'll be using a lt4 hot kam kit.
Question is are these pistons made for floating or pressed fit pin set up.
This is the piston from Cnc-Motorsports "383 4.030 3.750 5.7 1.425 10.4 9.8 9.2 -16cc 457 ". Here is the link http://www.cnc-motorsports.com/produ...599&CtgID=8206
Kevin
96 stoker Z
Dave88LX Nov 21, 2004 02:29 PM
Re: need help with pistons
"Pin fitting and double spiro locks included"
They're floating. Spiro locks go on the end of the pins to keep it in place.
Dave88LX Nov 21, 2004 02:30 PM
Same pistons I have except mine are for a 6" rod. Try adperformance.com, he should be able to get you a better price on them.
sskevinm Nov 21, 2004 02:43 PM
Thank You
Kevin
96 Stroker Z
