need help
i test drove a 94 camaro that i might buy today and it was awesome, but the only problem is at very slow speeds when i hit the gas it wouldnt really excelerate. mebbe i was just not hitting the gas enuff. afterall it wasnt my car so i was driving extra carefully. either that or something is wrong. what could it be if anything.
In my first act as a Moderator I am going to try to move this thread to "LT1 Tech" where I think you will be more likely to find an answer. This forum is for driveline issues (clutch, tranny, DS, rearend, etc.).
Good luck with your problem. Rich Krause |
TPS
This sounds like a throttle position sensor problem to me. you can check it with a multimeter im pretty sure, but i dont know the values that you would be looking for. Thats my initial feeling on the problem, maybe someone with a little more experience will chime in here.
CR |
| All times are GMT -5. The time now is 04:35 AM. |
