Need experienced plug help guys!
For some reason Im haveing alot of trouble lately with my plugs. Last week the car was running like crap so I changed the plugs out after about 3000 miles. #3 and #4 were fouled or just not getting spark because the ceramic was a dark brown, black and smelled really bad of gas. The others werent too bad with 1,2,5,8 all tan and 7 looked like it was going towards 3 and 4. The color line on the electrode was almost all the way towards the base meaning too hot of a plug right? So I went from an autolite 106 .050 gap to a 104 .050 gap and the same thing happened. So which is it too hot, too cold? etc.
What could the problem be? I have no knock retard and the A/F was set on the dyno.
My compression is 11.1 and I have way more horsepower than stock. Is a different heat range or gap on the plug needed for my motor?
Im sure someone will correct me if im wrong, but most people run the NGK TR55s gapped to .050 of NA applications. The TR6 is a very popular plug for those running nitrous and the tighter gap keeps the plug from having the spark blown out.
Aaron
Aaron
I went with a smaller gap because I had planned on sprayin after a while, so I went ahead and gapped them in between for now..I heard most peps go to a colder plug with a stroker..I am running 32 degrees timing at WOT and am getting 5-12degrees KR which is killing me..Still working on figuring that out..
Cody
Cody
Originally posted by Nostang 96z
I run 35 degrees of timing on NGK TR-55's with 11.5-1 compression and my car runs fine NA. I think it has to do with your idle and low RPM tuning.
Matt
Matt
Im running 35* right now so maybe thats whats hurting me. I didnt have any knock retard though which is weird...
