Is My Rear End Trashed? Help!!!!
Whenever i floor it from a dead stop or slow roll i get this crunching/ grinding sound from underneath the car. I looked under the car tonight and i noticed this black oily gunky stuff on the rear axle housing(pumpkin) and the rear axle. I just put on a brand new tranny mount and i checked the torque arm out and it looks fine. Please tell me my rear end isn't shot. Anyone.
take the diff cover off and see how many teeth fall out. 7.5" rears lick monkey nuts.. im on my 4th
So i take that as a yes. But why does it only make that noise at WOT.
Just pop the cover off and see. It took me three times...of WASTING money....before I took everyone's advice and installed a 12 bolt. No money.......then let it sit. You will be glad afterwards. You can buy an old Honda or something to drive while you save up. Everyone downtalks rice until your car breaks down...then you realize the gas mileage they get.
Joe:D |
Originally posted by FireAm94 Just pop the cover off and see. It took me three times...of WASTING money....before I took everyone's advice and installed a 12 bolt. No money.......then let it sit. You will be glad afterwards. You can buy an old Honda or something to drive while you save up. Everyone downtalks rice until your car breaks down...then you realize the gas mileage they get. Joe:D I recently had a 4.10 break in my car. I put the car on a lift and was inside it reving the gas and my buddy was under the car with his hand on the housing and it was knocking like hell. Come to find out it was broken. |
Re: Is My Rear End Trashed? Help!!!!
Originally posted by gamboa Whenever i floor it from a dead stop or slow roll i get this crunching/ grinding sound from underneath the car. I looked under the car tonight and i noticed this black oily gunky stuff on the rear axle housing where it joins the rear axle. I just put on a brand new tranny mount and i checked the torque arm out and it looks fine. Please tell me my rear end isn't shot. Anyone. |
There is no way but to pop the cover to find out if the rear is trashed.....so no one can answer his question.
Joe:rolleyes: |
Originally posted by FireAm94 There is no way but to pop the cover to find out if the rear is trashed.....so no one can answer his question. Joe:rolleyes: |
how can u put fluid?
thru the plug on the side of the rearend
Originally posted by gamboa Whenever i floor it from a dead stop or slow roll i get this crunching/ grinding sound from underneath the car. I looked under the car tonight and i noticed this black oily gunky stuff on the rear axle housing where it joins the rear axle. |
It would NOT be a wise move to NOT check the gears after running the rear out of fluid....especially with grinding noises. Think about it.
Joe |
Re: Re: Is My Rear End Trashed? Help!!!!
Originally posted by norcalstreet I'm not sure what you're talking about. Do you mean the rearend cover or where the yolk connects to the rearend? (The yolk being what the driveshaft attaches to) |
I trashed mine when I was stock. Not sure what happend, never heard anything.
I changed the fluid one day, found a chunk. Took it in under warranty. The chunk was actually part of the diff, and fubard a lot of things. The bill was over $1400, thank god for the GMPP. :) |
Thanks for the help everyone. Gonna bring it in to the shop this friday. My warranty expires in about 5 weeks. Hope it's covered
| All times are GMT -5. The time now is 07:20 AM. |
