My next project...
Need suggestions from the gurus again :)
1994 Camaro Z28 (LT1/ 4L60E) 116K Miles Moroso Cold Air Intake 52mm TB Hypertech Adjustable Fuel Pressure Regulator Crane Energizer 1.6 RR MSD Opti MSD 6AL Ignition MSD Coil MSD Wires Edelbrock ST Headers Magnaflow Catback; no cat converter 3.42 rear CSR Water Pump Hypertech 180 degree thermostat/fans programmed to come on early DMS Motorsports Performance Lowering Springs Lakewood Rear Lower Control Arms Rear Lower Control Arm Relocation Brackets Edelbrock Panhard Bar Custom 3000 stall converter, built based on weight of car, rear gear ratio, etc. CPT Transmission “Race” rebuild, updated “steel piston set for the input drum-http://cpt.pszweb.com/700.htm B&M Transmission Cooler Front 1LE Sway Bar *Heads Reworked: 2 Angle Valve Job, Gasket Matched Intake/ Exhaust, Blended Exhaust Port PCM Tune by PCM4LESS So, I'm torn between a new cam/ bigger head or going all the way with an LSX. I really like this 4l60e but, a 6 speed would also be nice. Are there any cams that would work well with my 3000 stall? I'm also assuming I would need a new rear end if I took the LSX route? I'd love any suggestions. Thanks, Sam |
Re: My next project...
LT4 Hotcam would work for you but you'll also need better valve springs.
anything else like lifters or pushrods? Does it work with the OBD1 style optispark? What sort of performance gains could I expect from that with a proper tune?
Do you already have everything listed in the first post? There are a couple questionable items on the list. For example, why do you need an adjustable fuel pressure regulator? Why a stock temp t'stat, rather than a 160°F? Why an MSD Opti? Offers no advantage over the AC Delco.
Originally Posted by Injuneer
(Post 6975342)
edit: also I believe the 180 t-stat was a typo when I asked for details from the previous owner. |
