my list of mods, what do ya think?
MAF, 52mm TB, 2400 stall, comp cam, b&m high perf. kit, long tubes, cai, and roller rockers. debating 3.73's and msd. still a daily, please feel free to fill in the blanks or make suggestions. were should i be on the horse power scale?
Re: my list of mods, what do ya think?
i would say if you have a 2.73 change to a 3.73 god i did and it made the world of differnce biggest seat of the pants mod i have done yet and its not that bad on the interstate
What comp cams? who made the converter? Do you have a cat-back exhaust, do you have a cat?
i was lookin at the tci Break-a-way converter and im guna match the specs for the cam witch is 265-280. stock exhust with flowmaster and gutted cat and soon to have headers.
Go with a 3 inch cat-back for the exhaust piping, biiig difference. I don't care for the TCI stuff (or the B&M). The SLP converter has had alot of success with people, but I looove my vigilante.
I would look around at the cams, if youre wanting to keep the chop low go with more lift, and keep your .050 duration numbers in the 210 int-220 exh range, it will be mild but better than stock. If you change cams you'll need springs as well. I like the CC 218/224 cam it's nice and has a mild chop , but not bad, the 224/240 is nice as well as the cc305, but they will be much choppier (but make more power). |
would cc 218/224 cam go good with the 2400 stall converter?
Yes they will work very nicely together.
With a full exhaust (LT headers, no cat, and 3 inch cat-back) a CAI, the cam in question and a good tune (with other little mods like pullies, rockers etc) you should easily see 330 rwhp without head work. But if it ends up with 310 rwhp or so I wouldnt be surprised. |
There are lots of good small cams available. I will really depend on if you
want some lope in the idle or if a near stock idle is OK. You can make almost as much power with cams like the Crane 227, TPIS ZZ9, and GM 845 as you can with the Hot Cam and others slightly bigger. So what's the verdict, a sleeper stock idle or a lopey idle? I do like the very near stock idle of the 227 and like to think I'm in the "sleeper" category with my cast iron exhaust manifolds. So it will depend on what your goal is. |
