is my crank sprocket on far enough? **picture**
Old Mar 11, 2004 | 12:58 PM
sc93's Avatar
http://users.zoominternet.net/~sc93/cranksprocket.jpg
Kind of hard to see from that angle, but there is a little bit of space behind the gear still. The gear is completely over key (not sure what you call it) on the shaft, but there is still some room back there.
Should I pound it on until it is flush up against there?
Old Mar 11, 2004 | 01:57 PM
rmackintosh's Avatar
...that pic is a bad angle....can't tell if it is flush or not....but yes...put it on so it is contacting metal to metal....all the way
Old Mar 11, 2004 | 02:02 PM
sc93's Avatar
thank you!
Old Mar 11, 2004 | 02:21 PM
96ta(nick)'s Avatar
the back of the sprocket has a lip that sticks out so it looks good to me..
and be sure to clean out all that crap about to fall into your oil pan
Old Mar 11, 2004 | 03:21 PM
If it is bottoming out on the front of the crank boss, it's on all the way.
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
