My car has kind of a sweet smell when I get out
Old Oct 19, 2003 | 11:37 PM
NeoSNK's Avatar
It smells kind of sweet around the engine. Is that a sign of running rich?
Old Oct 19, 2003 | 11:38 PM
RamAir95TA's Avatar
Maybe you should have changed your oil with oil and not maple syrup?
Old Oct 19, 2003 | 11:40 PM
96LT14u2Nv's Avatar
a sweet smell is usually hot engine coolant from overheating. is it getting too hot?
Old Oct 19, 2003 | 11:44 PM
b-stevens's Avatar
hehehe lately this forum has gotten alot of smartass comments, hopefully im not the only one laughing
Old Oct 19, 2003 | 11:45 PM
RamAir95TA's Avatar
It's just a joke...I don't think anyone will take it personally. Rarely do I have a smart-*** comment to make.
Old Oct 19, 2003 | 11:47 PM
b-stevens's Avatar
yeah i was looking for a word like "joke" but it didnt fit in with my sentence too well
Old Oct 19, 2003 | 11:56 PM
ninetythreez's Avatar
It may be leaking from the water pump so find out before it damages the opti spark or you'll be walking instead or driving. Other common spot is passenger side front floorboard where heater core is located under dash behind glove box. Check passenger side front carpet for wet spots after driving. Also check freeze plugs (a.k.a. expansion plugs) on block for leaks. Most common one is the one next to the starter where water pressure is low and deposits in coolant system gather and rust out the stock freeze plugs. If they need replacing, go with a brass freeze plug. freeze plug size is same on all the 350 blocks. Good luck!
(There's a big difference between a joke and a smart a$$ comment.) I had a funny answer to that also. Glad I didn't post it now.
Old Oct 20, 2003 | 07:13 AM
NeoSNK's Avatar
The top hose is leaking onto the waterpump. I've tightened it up and it still does it. I guess I'll tighten it a little more.
Old Oct 20, 2003 | 08:37 AM
Fatdog's Avatar
Cool
Before I replaced my top radiator hose,I had to double clamp the top part to keep it from leaking,I couldn't tighten the first clamp enough.The hose was as soft as a pancake.
Old Oct 20, 2003 | 12:29 PM
RENE95Z's Avatar
Too much syrup.
Sorry, couldn't resist.
cmdeshon
Dec 27, 2014 10:06 AM
ModdedNerd
Dec 18, 2014 10:52 PM
Dec 17, 2014 11:00 AM
USAirman93
Nov 24, 2014 03:37 PM
96CamZ
Jul 27, 2002 04:13 PM
