CamaroZ28.Com Message Board
-   -   MSD Placement (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/msd-placement-134345/)
Black_Z28 Jun 17, 2003 01:15 PM
MSD Placement
Where are you guys putting your MSD ignition module? It would be great if you had pictures of where you put it. Thanks a lot.
indy500ss Jun 17, 2003 01:30 PM
I have the Crane HI-6S and a Moroso CAI, I mounted the ignition box right above the K&N. Right about where the stock airbox filter hole is. I do not have any pics but it was a real clean, simple, and invisible install. If you have CAI and your box is roughly 2x3x6 this should work. Good luck.
FireAm94 Jun 17, 2003 01:32 PM
I put mine just in front of the strut tower on the drivers side...where it dips down. I think I barely had to move the fuel line bracket.
Joe
IDOXLR8 Jun 17, 2003 01:54 PM
You can also mount one on the firewall. Sorry I have no pics. :(
FireAm94 Jun 17, 2003 01:56 PM
Is it any easier to get to it to adjust?
Thanx
Joe
Black_Z28 Jun 17, 2003 04:53 PM
I just checked, and it won't fit in that area.
m0nk Jun 17, 2003 11:51 PM
http://members.aol.com/atomicm0nk/car.html
2nd picture down
if you want a close up I could take on for ya
Xscream Jun 18, 2003 08:28 AM
I second monks mounting spot.. Cole if you need help I can always help you out with it. Otherwise you can see how if fits on my car.
Black_Z28 Jun 18, 2003 12:10 PM
Sounds good Josh. I may have to take you up on that offer. But I have to replace my fuel pump first. I think it's on it's last leg.
m0nk- How did you secure the unit down? Sheet metal screws? And how long are they? Thanks a lot.
m0nk Jun 19, 2003 01:57 AM
Umm I would say the screws are about 1/4" after the bottom of the msd unit, only has 2 screws on the top R and top L, you can feel about 2 threads sticking out in the wheelwell
madwolf Jun 19, 2003 02:01 AM
Or you could mount it here. :)
Black_Z28 Jun 19, 2003 12:41 PM
Do you have any better pictures of the unit? It's kind of hard to tell how you mounted it there. Or if you could tell me how you did. :) Thanks.
madwolf Jun 19, 2003 12:43 PM
No better pics, but it's mounted on top of the plastic mudshield, right near the CAI filter...
DavesLT1 Sep 23, 2005 11:18 PM
Re: MSD Placement
I know this is a really old thread but I was looking at the placement areas here and the black cable that the wiring diagram says to go to the battery negative is too short, do I need to splice another length of cable (what gauge?) or can I just ground it to the chassis?
shoebox Sep 23, 2005 11:25 PM
Re: MSD Placement
You can easily ground it to the ground location by the headlights on top of the radiator support.
