MSD ignition
Old Jul 2, 2004 | 01:26 AM
Heatmaker's Avatar
Advanced Member
MSD ignition
Got the new MSD coil .... but wondering... just what in the hell are these brackets for? Are they needed on a 95 ingnition setup? Don't remember getting these last time.
Old Jul 2, 2004 | 01:28 AM
97WS6SCharged's Avatar
Which coil did you get?
Old Jul 2, 2004 | 01:35 AM
Heatmaker's Avatar
Advanced Member
P/N 8226 .... the GM blaster coil for 93-95 engines
Old Jul 2, 2004 | 01:44 AM
You should be able to drill out the pins holding the coil to the bracket and replace them with bolts. I'm not sure what brackets you're refering to.
Old Jul 2, 2004 | 01:48 AM
Heatmaker's Avatar
Advanced Member
Yep, that's exactly what I did last time when I installed the first coil.
But this coil came with a seperate bag with 4 screws and these 2 "L" shaped brakets.
Old Jul 2, 2004 | 01:53 AM
Probably so you could mount the coil to a firewall. That coil is meant to be used on different applications that use the two wire system. Are they sheet metal screws or just regular old screws?
Old Jul 2, 2004 | 02:12 AM
Heatmaker's Avatar
Advanced Member
thier black screws
Old Jul 2, 2004 | 06:07 AM
PatriotTA's Avatar
I got the same package. I don't know what that extra bag is for so I just threw it in with my extra parts that came with my 6AL. So if your question is do you need those, then nope, because I have been running without that extra stuff for some time now.
Old Jul 2, 2004 | 06:16 AM
Flip94ta's Avatar
Old Jul 2, 2004 | 07:57 AM
hairbear21's Avatar
The L-shaped screws are for older alppications. That coil can also be used on pre-93 engines. My '92 had that coil, and those brackets help mount that coil to the intake.
Old Jul 2, 2004 | 09:34 AM
Heatmaker's Avatar
Advanced Member
Cool enough...
But gee MSD has the worst installation instructions yet ... No words no details just a picture. So I'm searching for like an hour trying to find the right Allen wrech and crap. LOL's this was my fist mode on my car... and I remember why I was frustraighted back then.... but it still only took me a couple hours...
Old Jul 2, 2004 | 09:39 AM
hairbear21's Avatar
Try installing a 6AL box without the special connector!!! I put one on my '92 before they had the connector out and that was a nightmare! The instructions blew and I had to call tech. to get it to work.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
