msd ignition
Old Feb 4, 2004 | 10:15 PM
CamaroSS30thAnn's Avatar
msd ignition
what are my advantages and /or disadvantage of a MSD ignition...distributor...plugs and the 6a or whatever it is?? Thanks
Old Feb 5, 2004 | 06:28 AM
IDOXLR8's Avatar
Realistically for a stock car your will not see a benefit with an aftermarket ignition system. BTW MSD does not sell a distributor for an LT1. People typically go with an MSD ignition coil once there stocker goes bad.
Old Feb 5, 2004 | 07:43 AM
teke184's Avatar
if you plan to get an ignition box...
get the msd 6AL instead of just the 6a. the AL has a built in rev limiter that is much more effective than the stock limiter. alot of guys will have their stock limiter raise a little then put the 6al limiter at the stock setting...
stock cuts fuel to sequental cylinders...bad for nitrous use!
MSD cuts spark i beleive.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
