MSD blaster coil
I just did plugs and wires and was thinking about replacing the coil.Is it a good idea to use the msd with a stock ignition or should I just stick with a gm coil?
On a 1997, the stock coil is pretty good. No real reason to buy a new one if yours is working.
Does that still hold true if you have a 95? Or would the MSD help a 95?
A 1995 could benefit from a stronger coil. The coils were changed in 1996.
so would a msd blaster coil be on par with the 96 and up coils :confused:
Thanks!
Originally Posted by jessehotrod
(Post 4573011)
