MSD 6AL help
Old Feb 6, 2006 | 06:02 PM
bowtiethunder's Avatar
MSD 6AL help
Do you need the RPM module kits before it'll work? I bought a used 6AL four years ago for my old carbed 3rd gen. I never could get it to work and it didn't have the rpm pills. I would like to try it again on my current car. I will order the gm harness for it also.
Old Feb 6, 2006 | 06:07 PM
Projectz28's Avatar
Moderator
Re: MSD 6AL help
I am pretty sure you need to have a pill plugged in for it to work. Even if you buy a set of pills and the ign doesnt work, they will rebuild it for $80 or so....
Old Feb 11, 2006 | 10:41 AM
Re: MSD 6AL help
Well I got it all hooked up put a 6k pill in it and it started right up. It has good idle and throttle response. But it won't rev past 3k rpms it feels like the rev limiter. So then I took the 6k pill out and put 6.8k pill in and it goes to 3400 rpm. What could be the problem? I got the gm harness and new blaster coil.
Old Feb 11, 2006 | 10:44 AM
SnakeOiler's Avatar
Re: MSD 6AL help
make sure it is set for an 8cyl and not a 4cyl
Old Feb 11, 2006 | 10:56 AM
Re: MSD 6AL help
SnakeOiler where would that be?
Old Feb 11, 2006 | 11:01 AM
Boosted_Z28's Avatar
Re: MSD 6AL help
Go to this page of MSD's website and click on their instructions link. It will describe how to set the box for 8 cylinders:
http://www.msdignition.com/ignition_6_6420.htm
Old Feb 11, 2006 | 11:11 AM
SnakeOiler's Avatar
Re: MSD 6AL help
Uh yeah. . . I actually thought is was a switch you turned, obviously not. It's been about 7 years since I've even seen mine.
If both of the wires are cut then you are SOL unless you can get them soldered back together.
I guess another alternative is to get a 12,000rpm pill.
Old Feb 12, 2006 | 08:08 AM
Re: MSD 6AL help
Both wires was cut, the wires had some slack and I soldered them back. Works great now. Thanks guys.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
