CamaroZ28.Com Message Board
-   -   Which mount did I break?... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/mount-did-i-break-278394/)
Kurt Crosbie Jul 3, 2004 02:21 PM
It's coming from under my feet to the right. When I get on the gas or while I'm cruising if I go over any bump I get a clunk.
WhtLT1 Jul 3, 2004 02:22 PM
I'm gonna go with trans mount on this one
Lt1t56 Jul 4, 2004 01:19 AM
Second vote.... trans mount. Can you hold onto the shifter and accelerate and maybe see if you can feel the trans move around to help isolate problem ?
Kurt Crosbie Aug 11, 2004 06:21 PM
Re: Which mount did I break?...
Yea, I can definitly feel the shifter moving around. But I can hear clunking coming from anywhere from the front to the rear of the car.
Kurt Crosbie Aug 12, 2004 03:01 AM
ttt
ROADRAGE Aug 12, 2004 03:09 AM
Originally Posted by Kurt Crosbie
ttt
Trans mount. Go fix it
contraststriker Aug 12, 2004 07:39 AM
Yeah, this happened to my friend. It's gotta be the transmission mount.
RKB4C Aug 12, 2004 08:24 AM
It happens to my son's 95 TA (auto tranny) - every 3 months or so!
roadtrip120 Aug 12, 2004 01:34 PM
Trany or Torque Arm, my Torque arm bolt stripped out and fell out, and the torque arm would come up and hit the floor pan, but the drive shaft was binding up some as well, check both
Kurt Crosbie Aug 12, 2004 02:09 PM
Sorry if this sounds stupid, but how can I check the torque arm or the tranny mount itself? Can I wiggle the tranny with my hand?
screamin94Z Aug 12, 2004 02:14 PM
take it off and check it. you shouldnt be able to move the transmission with your hand.
magius231 Aug 12, 2004 03:26 PM
the tranny is pretty heavy so you probably won't be able to move it with your hand, but try putting a jack under it with some wood and see if you can move it that way, or use a long prybar and see if it moves. It shouldn't :)
Compstall Aug 12, 2004 03:32 PM
Anyone guess the trans. mount yet? :p
tomatocity Aug 12, 2004 04:10 PM
Does anyone have the part number(s) for the transmission mount(s), M6 and Auto? Is there a better transmission mount than stock?
ReducedFat Aug 12, 2004 04:54 PM
Engery Suspension makes a polyurethane tranny mount that's pretty hard to break, but in talking to the guys that have it I hear it causes pretty intense vibration throughout the whole car.
