Mixing and Matching
Old Jul 12, 2006 | 11:45 PM
SevenStars's Avatar
Mixing and Matching
So I've searched this for the last hour but I cant seem to find the answer to my question:
When I'm installing the windage tray in my LT1 (stock oil pan) is there any negative effect to running all ARP studs except for 3 used 400ci windage tray bolts so the tray clears my H-beam rods and crank?
And does ARP make any longer studs that would work for my application?
Old Jul 14, 2006 | 05:54 PM
SevenStars's Avatar
Re: Mixing and Matching
Any one???
Old Jul 14, 2006 | 06:27 PM
1racerdude's Avatar
ARP makes a set for the 400CID small block that will work. Ya don't want to mix the bolts.
Old Jul 14, 2006 | 07:31 PM
SevenStars's Avatar
Have you tried this? Because when I was checking I got the same ARP part number for the main studs on both the 350 and 400 so they should be the same. Thats where I got really confused.
Old Jul 16, 2006 | 08:32 PM
SevenStars's Avatar
I know I can't be the only one to have this problem...
Old Jul 16, 2006 | 09:21 PM
ulakovic22's Avatar
I had the same problem and just ditched the windage tray. You can clearnace the windage tray by cutting it out where the rod bolts contact it.
CARiD
Sep 30, 2015 05:44 AM
Sep 17, 2015 11:53 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
pimpen1024
Aug 19, 2015 08:36 PM
