Mini Starter Install With AS&M Headers
Old Apr 1, 2006 | 01:43 PM
TUFF LT1's Avatar
I just got my starter that I ordered from Summit. Went to install it and one of the long bolts that hold the starter together is hitting the collector on my header (AS&M). The P/N from Summit is SUM-820323. It's a mini starter so I didn't figure that I'd have any problems fitting it in there. I thought wrong. I know that some with the LT4 starter and AS&M's or RKSport headers have a tight fit, is anyone running this starter with AS&M's? Any ideas on what I can do, besides "send it back" Which is what I'll probably have to do. Thanks
Old Apr 1, 2006 | 03:05 PM
TUFF LT1's Avatar
Re: Mini Starter Install With AS&M Headers
I took another look and the mounting plate is adjustable. I rotated the starter but for some reason it won't bolt up. the inside bolt won't go in. It's almost like the teeth aren't meshing or something. It is a 153 tooth starter. Any Ideas? This is just a starter and it's kicking my butt.
Old Apr 1, 2006 | 09:09 PM
96SilverRam's Avatar
I have the exact same starter (chrome version) and it fits perferct ! I don't have ASM's so maybe the headers are the problem ? I have this installed on 96 LT1 with FLP Longtubes, I did have to reclock it to make it fit
Sorry for the low light on the pics:
Old Apr 4, 2006 | 08:31 PM
TUFF LT1's Avatar
I wanted to post the fix for installing this starter so it may help someone doing a search. With some help from those who posted, I found out that I had to grind/cut off a small chunk of the starter mount ( metal where the bolts go through ) where there was already a spot cut out to fit around the oil pan which wasn't big enough. I used a dremmel and a cutting wheel Now it works great. Thanks for everyone's help!
Old Apr 4, 2006 | 09:03 PM
BlackScreaminMachine's Avatar
All I can say is we did AS&M on a 93 T/A, The smallest starter CSR (csi) makes fits perfect, if it is the next size up (from the smallest) it hits the header.... very annoying.
Old Apr 5, 2006 | 06:12 AM
CANTONRACER's Avatar
I run this starter on my setup:
Smallest one I could find and it still barely fit.
Old Apr 5, 2006 | 08:48 PM
TUFF LT1's Avatar
Originally Posted by CANTONRACER
UPDATE--- After installing the exhaust the whole way I now found out that the starter hits the y pipe now, just barely but it does. So the headers are the problem with trying to find a starter that fits, not the starter. No matter how the starter is clocked it either hits the header collector, oil pan or the y pipe!!! And it's a mini. So in order to fit I'm going to have to "modify" or dent my y pipe so that the starter doesn't hit. I wouldn't do this but my y pipe is already damaged. Looks like the starter stated above is the only one that I've heard of that fits without modification, not including the stock starter.
Old Apr 5, 2006 | 09:21 PM
Thats the one I was refering too, it bearly fits, your right!
ModdedNerd
Feb 5, 2015 04:37 AM
dmcdonald96
Jan 30, 2015 06:46 AM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 18, 2014 12:57 PM
