Max Rev 383 LT1?
Old Jun 28, 2004 | 04:25 PM
Deenasty's Avatar
Max Rev 383 LT1?
I have a all forged 383 (heads and cam) The cam specs are 240/240 595/595 112. I know this cam is supposed to be reved kinda high in order to make some good power. What is a safe limit to be reeving the car to? The car right now has never seen anymore than 6k. I am just trying to prevent a spun bearing. Thanks guys!
Old Jun 28, 2004 | 04:38 PM
WS Sick's Avatar
Since you have a forged rotating assembly 6500 would be safe as long as the springs are in good shape. I have a cast steel crank and I rev to 6500 pretty regularly.(hyp pistons as well)
Old Jun 28, 2004 | 04:46 PM
Deenasty's Avatar
springs are rated to .625 lift so i guess they are ok..
Old Jun 28, 2004 | 04:55 PM
1racerdude's Avatar
revs
Your spring PRESSURE not max lift.With a forged bottom end,set up right you can turn 9000RPM's if you want.(Computer won't let you go that high-7000 limit)
Old Jun 28, 2004 | 05:34 PM
Spinner's Avatar
Your bottom end doesnt mean much. It's all about your bearings, and the BALANCE job. With 4 bolt mains and a good balance, you should be able to turn 7,000+ without issue. I turn my balanced stock bottomed end to 6800 (2-bolt)
Old Jun 28, 2004 | 06:29 PM
Deenasty's Avatar
its all balanced and blueprinted, built by a Chevrolet Dealership. Not that I chose to get it built there, just that when I bought it from a friend he had gotten it built there. Not because they are better in any means, but because he knew someone that worked there. The thing I am scared about is that it is only a 2 bolt main.
Old Jun 28, 2004 | 06:37 PM
1racerdude's Avatar
2bolt will be fine up to 600+FWHP if you are not running a butt load of NO or 25PSI blower,and if it is set up right.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
