Max lift on LT4 valve springs?
Old 08-10-2018, 01:39 PM
Bud M's Avatar
LT4 valve springs are rated at max lift .525 if I remember right. Is .528 pushing it? I assume not but just want opinions from more knowledgeable folks. Looking at CC501 w/ 1/6 rockers.
Bud M is offline
Old 08-10-2018, 03:10 PM
Chimera96's Avatar
Re: Max lift on LT4 valve springs?
I can't remember what LT4 spring max lift is but if it is .525 than .528 is flat out coil bind...so yeah that would be a problem. You ideally want about .030 margin before coil bind
LT4 springs are barely enough for the GM hot cam and if they already have mileage on them with standard LT1 valves they are done. They were designed to work with the sodium filled valves (lighter) on the LT4. They are a "OK" spring on a LT1 with a stock cam but that is about it
Chimera96 is offline
Old 08-18-2018, 02:12 PM
87Aerocoupe's Avatar
My car has the LT4 springs and 1.6 roller rockers and it flots the vales at 5800 rpm with the stock cam, IMO those valvesprings are junk.
87Aerocoupe is offline
Old 09-05-2018, 07:24 AM
KW Baraka's Avatar
Originally Posted by Bud M
LT4 valve springs are rated at max lift .525 if I remember right. Is .528 pushing it?.......
The LT4 springs will not handle this cam. You'll want (at the very least) the springs that Comp Cams recommends for this cam.
KW
KW Baraka is offline
MeanGreen97Z
12-13-2007 12:34 PM
blahster
12-04-2006 12:18 AM
Ultra_Dog
08-18-2005 02:21 PM
CColtManM
09-28-2004 07:50 PM
neat
09-04-2003 03:00 PM
Quick Reply: Max lift on LT4 valve springs?
