CamaroZ28.Com Message Board
-   -   Massive Surging!!!! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/massive-surging-127220/)
KillinFormula May 31, 2003 03:35 PM
Massive Surging!!!!
Ok i have one massive surging problem
here is what i have replaced and all is is perfect working condition
1) new fuel filter
2) injector cleaner
3) new taylor 8mm wires
4) new opti
5) new tr-6s for nitrous
What is going on with my car, any sugestions are welcome.
Fastbird93 May 31, 2003 04:28 PM
My 91 had terrible seuging problems right after I bought it. Turned out the fuel injectors were going bad. You may want to look at that if you have a lot of miles.
Lyle A May 31, 2003 05:12 PM
Is it throwing any codes? Mine was doing that and I replaced the O2 sensors and that made a difference. If one is faulty it can make your car run lean. I had a code 44 without a check engine light. After we did the work it cleared.
