CamaroZ28.Com Message Board
-   -   MAF sensor voltage?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/maf-sensor-voltage-190946/)
zmracing Nov 8, 2003 09:48 PM
My SES light is on and I went to Autozone and had them run a diagnostic check on it. The guy said it was a MAF sensor input voltage low. He said the sensor is not bad so I don't need any parts and it should not be causing any problems other than the light being triggered. Is this true or should I worry about it and try to find the cause of the problem?
zmracing Nov 9, 2003 11:14 AM
anyone have any ideas?
