Madz28 tune graph
Here are my dyno graphs that i got finally up you tell me what you guys think about the whole loss of power
Here ya go: http://www.innovativetuningdl.com/d....05/JKuczma.gif |
Re: Madz28 tune graph
linky no worky
your actual link goes to a website with "....." in it. Make sure you get the full url that would be in the address bar when you're viewing the picture.
sorry about that here it is http://www.innovativetuningdl.com/dy...05/JKuczma.gif
Hmmm.... I take it was just a bolt-on tune?
Did you have the sucker logged at all with any scanner. Mike |
Wheres the afr?
Were those runs done on the same day?
If the timing curves were changed, it could have been causing some KR and would cause what you see there.
2 degrees of KR has been seen to cause a drop of 10 ft/lbs of TQ on the dyno. |
Originally Posted by johnnyb
no they werent ( i remember from another thread)
KR i think im still a lil sleepy whats that
whats that and does Madz28 change that at all
A knock module/sensor detects knock(or false knock for that matter), and sends the signal to the computer causing it to retard the timing. i believe it can retard it up to 20*. THis can cause a major loss of power, my car lost .3 at the track just by it picking up FALSE knock. He desensitizes the knock tables or whatever they are i believe. There are alot of things that can cause Knock/false knock.
i dunno if he desincitzed mine or not
| All times are GMT -5. The time now is 08:08 AM. |
