CamaroZ28.Com Message Board
-   -   AS&M Header owners (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/m-header-owners-294882/)
fesgali Aug 24, 2004 03:07 PM
AS&M Header owners
How did you setup your plug wires? Stock, over valves? I know that the back passenger side one has to be a little longer and have a U shape curve. Any advice on wire sleeves?
Also, i get some rubbing with the pipe thats close to the steering column. I've heard that the LT1 column is adjustable, is this true?
MA
bad95formula Aug 24, 2004 04:14 PM
Re: AS&M Header owners
I used the stock routing for the wires. I removed all my AIR stuff so the install was much easier. i didnt have to adjust my steering at all. I'm damn glad I went with the AS&M's!!
steve40 Aug 24, 2004 05:00 PM
i used the stock locations
put the metal boots over the back 4 cylinders with the 6" fire sleeves. i also had to make a new wire for #8 as it was too short(msd wires)
Fastbird93 Aug 24, 2004 05:05 PM
I went over the valve covers. Pretty straight forward install on the driver side, but the passenger side was tricky because of the number two primary tube and it's position. Plug wires two, four, and eight would all go in from the top, but wire six was just too close IMO to the primary. So I routed number six over to the strut tower, then zip tied it to an A/C line, then ran it under that number two primary tube and over to the plug. Works like a charm.
JeffK Aug 24, 2004 05:31 PM
I put #8 and 6 behind the dipstick tube to keep it out of the way. My steering linkage touches ever so slightly.
Fastbird93 Aug 24, 2004 05:45 PM
I thought about doing that, but decided against it just due to the head that's in that area.
White Knight 95 Aug 25, 2004 03:09 PM
I used the stock locations and clips, and have only had one singed wire due to a melted clip. Otherwise the stock location seems fine.
I had no rubbing on the steering column, but did have a slight fitment issue in the collector. Nothing a little brute force couldn't fix.
marshall93z Aug 25, 2004 03:11 PM
i burnt, what i think, was my cruise control wire....or something. the number one primary was close to the body and burnt it! damnit...
Fastbird93 Aug 25, 2004 04:59 PM
Ditto!!!!
Heatmaker Aug 25, 2004 05:03 PM
Where might this cruise control wire be located?
marshall93z Aug 25, 2004 09:48 PM
between the number one primary and the body, right where it comes out ot the port...
