LTCC Question
I am going to be purchasing thte LTCC unit soon. I see that they say to use the Taylor Spiro-pro wires. Does anyone have a part number for these or anything that will work with these? Thanks in advance!
Re: LTCC Question
who's they??? Bob recomended the Magnecor's for me.
-b |
Re: LTCC Question
I think I will be buying it from Full Throttle Speed. On the bottom it says those wires. (NOT ultra-low resistance type). Do you have the part number for the wires that you have. I don't mind making my own. I just want to make sure they have the correct ends. I will run whatever works best. Thanx
Re: LTCC Question
I got mine from Thunder Racing.
04-73251 Taylor Spiro-Pro 8mm Universal Wire Kit, 90 degree boots, RED $53.99 and 04-46052 Taylor Opti-Spark End Terminal Kit $14.99 :) |
Re: LTCC Question
If you go the magnecor route you have to go custom. If you want your own custom set let me know I'll get there # and get you a measurement on mine to give you an idea. Money wise there more expensive I think I paid like $110 for them.
-b |
Re: LTCC Question
Ive put Taylor Spiro-Pro's on an LTCC setups and they are perfect. Spiro-pro's are a standard suppression plug wire so they work very well with the ltcc.
Re: LTCC Question
Looks like I will be going with the Taylor wires. Thanks for the help guys!
| All times are GMT -5. The time now is 09:34 AM. |
