| mighty_casey13 |
Jul 21, 2007 10:20 PM |
ltcc conversion kit
i replaced the opti spark with the ltcc conversion kit on my 1994 camaro z28. this was a while ago. recently i have been having some problems with it and im pretty sure it has to do with the kit. car took a little while to start. also when it is running in idle, it shakes back and forth, almost as if it is going to stall but the rpms never go lower, and if they do it is hardly noticeable. i did also notice my battery meter seems to be lower than usual at times when the car is idling, then it picks back up again when im driving. took the cover off the box(connects to the ltcc kit) and it read there is an error (flashing red diode). anyone ever had any of the same problems?
