LT4 Springs
Old Jan 31, 2006 | 01:01 PM
1quickTA's Avatar
LT4 Springs
I know a lot of people have mentioned that the LT4 springs that come with the HotCam kit aren't very good.....but how bad are they and what symptoms? I am planning on installing a hotcam kit and was wondering if I really should upgrade them or not. If so, to what and how much $$$
Old Jan 31, 2006 | 02:04 PM
TM88GT's Avatar
Re: LT4 Springs
They are good springs for a small cam (up to .525 lift). If your cam has more lift, then you'll need better springs
Old Jan 31, 2006 | 03:25 PM
truedualws6's Avatar
Re: LT4 Springs
It's not that they are no good. They are OK as springs go, but they are
limited in maximum lift potential. If installed at 1.78" they only provide
.035" to coil bind with the Hot Cam kit. I prefer to see a .050" minimum
margin to coil bind. I ran them with the stock cam and 1.6 rockers and
they worked just fine.
Old Jan 31, 2006 | 05:17 PM
1quickTA's Avatar
Re: LT4 Springs
That is what I was worried about, the .035" tolerance vs. something more. I really don't know all that much about valvetrains yet and was wondering if I should upgrade springs? What are some good but not too expensive alternatives that wont require any machining of the heads (just drop right in)?
Also, saying that I do get coil bind, what happens??? bent pushrods? what else? I want to get a good idea of what to expect.
Old Jan 31, 2006 | 05:29 PM
sbs's Avatar
sbs
Re: LT4 Springs
GM specified those springs to go with that cam and those rockers. Bazillions of people are running that kit with no problems
Old Jan 31, 2006 | 05:37 PM
1quickTA's Avatar
Re: LT4 Springs
Yeah, I figured that but just reading all the posts about them not having enough clearance to coil bind kind of had me freaked out. Thanks for the input!
Old Jan 31, 2006 | 07:20 PM
RE AND CHERYL's Avatar
Re: LT4 Springs
Bent pushrods and broken springs are the two main consequences of coil bind. I think there was a broken valve spring thread a week or so ago that was the direct result of coil bind.
Re'
Old Jan 31, 2006 | 09:52 PM
Re: LT4 Springs
There are lots of spring options out there. The Isky 235-D may be worth
considering if your budget is limited. It's been a while but I think you will
need some L98 spring seats. The springs are about $90 and the seats
should be about $1.49 each. The rest of the stock hardware should work.
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
