lt4 question
-Gaskets for: Water Pump, Timing chain cover, intake
-The three seals in the timing chain cover
-Valve seals (while your changing the springs)
-oil
-radiator fluid
-air conditioning recharged
-plugs and wires?
Plus the usual stuff like tools, manual, bolts to pull the hub, a good web sight to refer to, and some mechanical inclination.
This might be a good place to start.
http://www.streetillusionsracing.com...ll/install.htm
-oil
-radiator fluid
-plugs and wires?
95chwagon
Jan 13, 2015 09:19 PM
