LT4 Knock Module
Old May 27, 2004 | 11:52 AM
19camaro71's Avatar
LT4 Knock Module
I have heard the the LT4 knock module can be transplanted into 94+ cars, but I have found nothing on them going into 93 cars.
Is it possible to put the LT4 knock module into a 1993 Formula?
What all is involved in putting one in, Do I just need to pick up the module itself or do i need more?
Old May 27, 2004 | 01:55 PM
Red96Lt1's Avatar
Fo 94+ all you need is the module. On your car I'm not sure if it will fit or even if you have one. Check on the PCM. There is an aluminum plate with 2 screws and 3 vents on the plate. That is where the KM goes. So see if you have it.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
