CamaroZ28.Com Message Board
-   -   LT4 intake without the powder coating? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lt4-intake-without-powder-coating-226007/)
EddieP Feb 17, 2004 01:24 PM
Is it possible to purchase an LT4 intake without the powder coating? Alternatively, has anyone successfully stripped the powder coating off?
carlos64030 Feb 17, 2004 01:47 PM
The LT4 intake only comes in red, and from my understanding it was done up in red for identification purposes.
OldSStroker Feb 17, 2004 02:13 PM
I've seen one get stripped. That is some sticky powder! Even had it on the bottom, if I remember correctly.
EddieP Feb 17, 2004 02:16 PM
I've seen powder coating "flake" off very smooth metal surfaces, but I figured it would cling pretty well to that cast aluminum.
How did they strip it? Chemically?
atljar Feb 17, 2004 02:48 PM
bead blast it
OldSStroker Feb 17, 2004 03:30 PM
Originally posted by atljar
bead blast it
Only if you aren't paying by the hour! Beads like to bounce off powder.
atljar Feb 17, 2004 03:35 PM
Sand blast it :D
EviLZ28 Feb 17, 2004 03:41 PM
My brother owns a powder coating company and he has a chemical which he dips the Intake in overnight that removes all the powder. He did it to both of my Cars LT4 intakes and redid one in Candy Blue and the other in Yellow.
arnie Feb 18, 2004 06:58 PM
Sand blast it :D
Works fine, even if charged by the hour. :) Comes right off, just use clay or tape to seal any passages.
Mr.Whitey Feb 18, 2004 08:59 PM
Check your local paint supply shop for a product called Tal-Strip. Trust me, it'll remove it in about 15 minutes. Every once in a while you'll have to slop some more on to a spot or two and then it's all gone. The cost is like $15/gal. and there are two versions available, 1 and 2, get 1.
Sand blasting may work but will take some time. If a powder has been applied properly it's a real HUGE PIA to remove. To remove all of the powder on an LT1 intake takes me about 30 minutes with a good blasting system.
