lt4 intake
Old Apr 24, 2005 | 09:48 PM
benji's_z28's Avatar
lt4 intake
i have to pull my intake to fix the seal and was wondering if an lt4 intake would work w/ my stock lt1 heads or if u guys recomend something different. i plan on putting a heads and cam in it in the future. thanx
Old Apr 24, 2005 | 10:42 PM
blackztpi's Avatar
Re: lt4 intake
no it will not work. lt4 heads and intake use a taller port, which would exceed the height of the lt1 head if you tried to put an lt4 intake on it.
Old Apr 25, 2005 | 09:53 PM
arnie's Avatar
Re: lt4 intake
As you have a '94, there is a good chance you have an intake with a crisp, true rectangular shape at the port entrance. As such, from GM, this has caused a mismatch with the smaller head port opening. The LT4 intake has SMALLER irregular shaped port openings, similar to that of your head port openings. That being the case, a swap to the LT4 intake, (as well as to a late LT1 intake) will eliminate the head port to intake manifold port (larger into smaller) mismatch. Other than correcting the mismatch by going with the SMALLER port LT4 manifold, (unmodified/unported) the swap will result in no advantage, power wise.
Old Apr 25, 2005 | 10:02 PM
Re: lt4 intake
Besides all that, it won't even bolt on without some machining for clearance because of extra meat at the end of the runners where it meets the head.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
