96 Z28 rough idling and running
Well.. since my other thread was closed I just wanted to report back that I took my car to the muffler shop, and I was wrong, it was not the cat converters. There was one problem, the gasket at the collector on the exhaust was leaking and they replaced it. It still ran like crap so I took it to a family owned auto repair shop, Webb Automotive, and explained the issue to them. Plus I gave them a whole laundry list of items to check that I have been wanting to be fixed for a long time. I'll find out tomorrow sometime what it will take to fix it.
Re: 96 Z28 rough idling and running
One thing to remember about the 96 and 97 cars (obd2) is that monitor a lot of things..including cat con efficiency. The car can tell you what's making it sick...for the most part. Unfortunately, it doesn't diagnose the distributor very well....
Thanks. I have scanned my Camaro several times, the muffler shop even had a computer and scanned it, and not a single error code.
My original thought was the optispark, but with my recent batting percentage, I hate to even venture a guess.
I wish I would have never bought this car..... well it was my big idea for a loan payback from someone. They had a 94 and this 96 Camaro and he agreed to let me take my pick of the two. The 96 was the better car, with leather interior, less body damage. It still needed work, more than what I realized, and I have honestly put close to $30k into this car with body work and complete paint job, interior repair, wheels and tires, engine rebuild, engine repairs, TB, CAI, Cam, headers, Magnaflow exhaust, etc, etc, etc, etc. Sometimes I feel like tossing a hand grenade inside the car or something. It has been a source of almost divorce for me and my wife. Geez loueez.
Did it run correctly after the rebuild and then suddenly start running badly or has it run poorly from the start? A big cause of problems is an incorrectly installed opti. It's supposed to go on one way but...and it happens a lot....people get it wrong. The car will act like a real dog as the timing is way, way off.
Another issue is cam timing but hat's usually when you do the cam with he engine in the car. If the cam is off by one tooth on the timing gear you have a significant timing issue and, again, a real dog.
The good news is that both of these are cheap to fixbut a pain in the...well you know where. If your shop can't figure it out do a compression test...ifit's low but even it's probably the cam timing.
Although I had to take my Camaro back for new fuel injectors and a couple of other problems, it ran good after the rebuild and like a bat out of hell after the rebuilt engine was broke in. Then came the Purge solenoid valve, evap canister, evap control valve, O2 sensors, LT4 knock module and on and on we go, where it stops, don't think I'll ever know! You hit the nail on the head when you it being sick.... it is dreadfully sick. It ran better than this before I got any work done on it. Well at least my son replaced a right bent axle on it for free!
james55 has requested that I close his account. I will honor his request:
james55 ( mailto:jameselder1@gmail.com ) has reported this post:
Re: 96 Camaro Z28 rough idle, car shakes at lower RPM's when in gear
https://www.camaroz28.com/forums/lt1...2/#post6930214
This is part of this thread:
https://www.camaroz28.com/forums/lt1...n-gear-871226/
This is the reason that the user gave:
I would like to report you and slick1 troll as being the most arrogant jackasses on any forum I have ever been on. So what if I dont bow down to you and agree with everything you say.
And secondly, screw you for closing my thread.
Funny thing is shoebox never openly complained. Only you and slick**** did.
You need to grow up and be a better moderator. You can start by deleting my account.
This message has been sent to all moderators of this forum, or all administrators if there are no moderators.
Please respond to this post as applicable.
F(ast)-body
02-26-2003 09:05 AM
