LT4 ED chain with what cover?
I did a search and posted another thread but still don't have an answer. I have a 93 LT1 twin turbo I'm doing for a 69 Camaro. The short block is together and I need a timing chain. I wanted to run the LT4 ED setup. I am NOT using the opti, I've converted to a rear distributor. I also have to keep the stock water pump because of front clearance issues, the electric won't fit.
Can I run the LT4ED with the stock 93 timing cover and water pump drive or is the shaft spline different? I know you change them to the late cover normally on this swap because the opti drive changed, but I'm not using that. Thanks guys! Jody |
Re: LT4 ED chain with what cover?
I believe you need to run the 95+ cover due to clearance, but don't quote me on that.
Should be fine. Only differences are for the opti in 95 and than the crank position sensor in 96-97 LT1s.
Thanks guys. They look to be about the same depth according to pics, but I wasn't sure. Obviously the OPTI drive is different on the cam gear which means you need the 95 cover, but since I'm not running it I should be fine. Just trying to get the right parts lined up without sending stuff back!
Thanks again. Jody |
Check this site out: http://www.automotiverebuilder.com/ar/ar99928.htm
Thanks guys!
Jody |
