LT4 Conversion Question
I'm looking to swap my 93 LT1 intake to an Lt4 Intake, gonna run AFR heads. Looks like I can pick up an LT4 intake for $240.00 from Summitt, it's a GMPP part so I'll probably call Jason as well. Intake does not come with fuel rails. Id did a quick search and it looks like all I need is 94 or later fuel raills to make it work. Can someone verify that this is correct.
Thanks. |
Re: LT4 Conversion Question
You can use your 93' fuel rail, but it would look better with 94+ fuel rail with the cross over in the front.
| All times are GMT -5. The time now is 08:19 AM. |
