lt4 or 383 stoker
i am having a hard time which to go for. i like the lt1 350 but i wanna get more power.
so which is good to go the 383 or lt4 swap! and please post good information about them! |
I have a 4 bolt main LT1 383 stroker with AFR LT4 heads and a ported LT4 intake...that's just me though....:D
Are you looking to do an actual LT4 swap, or just heads/intake/cam? |
port you stock heads and pick up a cam. THe lt4 top end isnt worth the money, for that much money you could go le3.
Or you could pick up the LT4 top end, have Lloyd turn it into an LE3 then toss that on top of a 383.
And if your goal is only to hit a 12.5, either one of your options would probably get there. |
le3? what that!
