LT1's with non-stock cams...What is your MAX. RPM's
Old Aug 11, 2006 | 11:30 AM
wrd1972's Avatar
I am trying to get an idea of how high you guys are spinning your engine with your aftermarket cams. Many here like me want to ensure they are installing the right cam that suits there needs. I want the best cam with a 6k-6.2k shiftpoint.
Please post the following.
1. What aftermarket cam (specs would be nice)
2. Heads ported or not.
3. Maximum RPM you shift at for best performance.
Old Aug 11, 2006 | 11:39 AM
93redBirdMan's Avatar
Re: LT1's with non-stock cams...What is your MAX. RPM's
Well for most bolt on applications people at reving to 6000 to get the most power. I know my motor on the dyno suggests I should be shifting at 6,000. Anyways, any aftermarket cam is going to be reved higher whether it's 100rpm over stock or 1000rpms over stock is all dependent on the heads/cam like you said. But even a small cam like the crane 227 (210/224) wants to be spun to 6100 or 6200. My buddy here in town had it with ported heads and he was still pulling strong at 6200 rpms. Honestly if you dont want to rev your motor high, dont get a large cam. Stay under the hotcam or so (218/228 i believe). And even that one wants to rev to 6400 or so...
Old Aug 11, 2006 | 11:42 AM
matLT1's Avatar
I have the cc503 cam. I didn't have any head porting done, they are just the stockers reconditioned. The guys at PCMforless set the shift points in my A4 for around 6.1-6.2k. The engine pulls really hard up top with no real loss in the lowend wchich is perfect for me because I drive the car to work when it is nice out.
Old Aug 11, 2006 | 12:07 PM
vin1382's Avatar
have mods in sig, shifts about ~6200-6400. have put about 5000 miles since install. so far no problems..although i have recently picked up an SES, and will have to check it out.
Old Aug 11, 2006 | 12:41 PM
speed_demon24's Avatar
If you are going to shift at 6-6200 max I would get the crane 227 cam, I had that cam in my car, it was a torque monster, and performed great too.
Old Aug 11, 2006 | 02:05 PM
kingman109's Avatar
cc XE 230/236 112 lsa
1.6 NSA promags 7/16 studs
918 beehives
comp chromally pushrods
10 degree locks/ retainers
stock heads -
rev to 6400-
Old Aug 11, 2006 | 04:49 PM
Hybrid86Z's Avatar
6500 here. w/ custom Bret Bauer camshaft
Old Aug 11, 2006 | 05:11 PM
Formula305fi's Avatar
I shift @ about 6300-6400.. Peaks @ 6500. Thats wit crappy cm-611 springs also.... BTW dont listen 2 speed_demon24 he wont run me down rt.27. Puss :-P
Old Aug 11, 2006 | 06:05 PM
Hybrid86Z's Avatar
yeah robert's a ***** :P
Old Aug 11, 2006 | 06:45 PM
Formula305fi, you say what you rev and dont even tell us with what cam?? Isnt that the whole thing were trying to help this guy with, choosing a cam?
Old Aug 11, 2006 | 07:07 PM
KENS96M6's Avatar
6500RPMs, with the 847 cam.
Old Aug 11, 2006 | 07:11 PM
Chopstix's Avatar
GTP#5 in a H/C LT1 shifting at 6500
222/228 .544/.538 112 396cid GTP heads peak started to lose hp at 6200
246/254 .613/.590 112 396cid GTP heads peak should be in the 65-68 range
Old Aug 11, 2006 | 07:42 PM
96capricemgr's Avatar
I have the AI 190cc package the cam is mid 220s intake shifts commanded around 6000rpms, if the weather is good and the motor pulling really hard it will just barely hit 6400 during the 1-2 shift. 100K mile stock shortblock, put a mild ZZ3 cam in it at about 60-65K miles and did the AI package at 95K miles.
Old Aug 11, 2006 | 09:22 PM
Green95Z28's Avatar
i have stock heads, with a LT4 hot cam and I shift at 6200-6400 to run my best ETS. (thats with 3.55 gears)
Old Aug 12, 2006 | 01:59 AM
hvyss's Avatar
I run the XE 224/230 or CC503 and with the LE2 heads. I shift at 6400 and the car is still pulling hard on every shift.
HVY SS
