LT1 Swap
Old Oct 31, 2004 | 11:13 PM
Drakar's Avatar
Angry LT1 Swap
I have this same question in 3rd Gen Tech wasn't sure which area to post.
Ok some background, I swapped a 96 LT1 from a b-body, and had it programmed back to 95 and OBDI with VATS/AIR/CAGS/A/C/EGR delete.
I can turn the engine over now, and I get spark fuel pump running, everything, EXCEPT the injectors aren't firing, I have power to them, but it's like the PCM is not triggering the injectors, or so I thought.
I tested the injectors and they fire, and I tested the PCM and it runs my dads roadmaster wagon for 2 seconds until vats kills it. (I know need to recheck it is programmed out) but on my car it just does nothing as far as injectors.
anyones thoughts on this is appreciated.
thanks
Old Oct 31, 2004 | 11:19 PM
madwolf's Avatar
Re: LT1 Swap
Maybe your injectors are clogged? When I swapped a 94 engine in my 93, I was having the exact same problems. I swapped the injectors and everything worked fine. The engine sat for a couple of years before I swapped it so the injectors rusted inside and were letting no fuel flow through them.
Old Oct 31, 2004 | 11:37 PM
Drakar's Avatar
Re: LT1 Swap
I thought that, but I "test" fired each one with 12V from the batt and only 1 is dead (currently finding replacements on ebay).
Old Nov 1, 2004 | 06:31 AM
Flyin_Z28's Avatar
Re: LT1 Swap
If you need some stock injectors, I can sell you mine with only 35,000 miles on them. (cheap cause I have no use for them).
Old Nov 1, 2004 | 07:49 AM
camaroKid223's Avatar
Re: LT1 Swap
i dont know if you have checked this or not but we did an lt1 swap in a friends v6 last weekend and had a prob much the same. after looking at my lt1 we noticed that he was missing one of the two wireing harnesses on the pass. side shock tower. maybe you are as well?
Old Nov 1, 2004 | 10:10 AM
Drakar's Avatar
Re: LT1 Swap
not sure, I know I have to complete Buick harness, as I pulled the engine and harness originally, I only cut once I was inside the car, so everything from the firewall into the engine is complete.
I might have to unwrap and check through it thought.
Old Nov 1, 2004 | 12:05 PM
6SpeedIROC's Avatar
Re: LT1 Swap
Do you have the wiring diagram from the Buick?
Check the wiring from each injector to the ECM connectors for continuity..injector fuse?
Old Nov 1, 2004 | 12:09 PM
Drakar's Avatar
Re: LT1 Swap
Continuity is perfect for all 8 injectors. Power is coming down on the other wire, 12V+ Fuses are still good.
Is there something in the ingnition wiring that would cause them not to fire?
I just don't get if the spark plugs fire then the PCM must be seeing the correct information as far as ignition and turning over.
Old Nov 1, 2004 | 12:17 PM
6SpeedIROC's Avatar
Re: LT1 Swap
Not sure about the ignition effecting the injectors..don't think so.
Are you sure you have fuel pressure at the rails?
If your PCM has the VATs removed, why would you dads car shut off with your PCM running it?
Old Nov 1, 2004 | 12:20 PM
Drakar's Avatar
Re: LT1 Swap
I suspect VATS hasn't been properly disabled, we are using LT1 Edit, if you have any insight into that.
And I do have fuel and pressure at the injectors, as I did test fire them, and the car would start and then die as the fuel in each cylinder was used up.
Old Nov 1, 2004 | 12:23 PM
6SpeedIROC's Avatar
Re: LT1 Swap
Sorry, never used it. I had my PCM done at Agostino in Toronto, I've never touched it myself.
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
