Lt1 overheating
Old Mar 8, 2008 | 06:05 PM
86Camarolt1's Avatar
Lt1 overheating
Just wrapping up the rest of lt1 swap, installed an aftermarket temperature gauge and its reading over 200, and spits the water/antifreeze back out to coolant tank continuously. any suggestions
Old Mar 8, 2008 | 08:53 PM
JooneJune's Avatar
Clogged up somewhere? is it a new cooling system or used?
was the LT1 from a scrap yard? how long did it sit? you mite have a clog in the block somewhere if you didn't tear into it.
Old Mar 8, 2008 | 09:10 PM
it sat for bout a year, but I do not have the 2 small necks under the radiator cap hooked up and I found my water pump leaking from its weep hole
Old Mar 8, 2008 | 10:48 PM
ss.slp.ls1's Avatar
Normal operating temp is ~226* before the fans kick on. If coolant is coming out of the overflow tank I would suspect a bad radiator cap.
Old Mar 8, 2008 | 11:00 PM
226? I thought it was less than that
Old Mar 9, 2008 | 04:46 AM
ssbowtie1's Avatar
Depends if you're moving or not. My car has an EWP and stock cooling system otherwise and runs at 170-180 while driving and goes all the way up to 230-235 while idling before the fans kick on and bring the temp back to the 210 range. If you hear bubbling its likely you have a bad radiator cap. Replace the water pump since you're leaking from the weephole. Then replace the radiator cap. Fill the system and bleed it from the bleed screws.
Old Mar 9, 2008 | 08:22 AM
Nope. A stock 4th gen also uses an 18 psi cooling system.
Old Mar 9, 2008 | 11:07 AM
would I have to hook up the 2 small necks under the radiator cap? one is for the coolant tank, and the other goes to back of heads but do I need these hooked up to run normal temperature
Old Mar 9, 2008 | 11:33 AM
LSWHO's Avatar
On my temp gauge 220 is a couple milimeters from the redline?!
Old Mar 9, 2008 | 04:38 PM
ss.slp.ls1's Avatar
Are the openings sealed off? Some people run without a steam pipe without a problem while others have problems with hotspots. I would think that you would need an overflow tank to run properly.
I don't know how that is posible, 210* is straight up and down. Redline should be around 360*.
Old Mar 9, 2008 | 04:56 PM
no they not blocked off, I found the reverse cooling line so now I just need a hose to connect it to radiator.
Old Mar 9, 2008 | 06:18 PM
LSWHO's Avatar
I dont either. Maybe thats why I'm "overheating." the PCM says 220 at almost the red.
Old Mar 12, 2008 | 10:31 AM
c0rey's Avatar
What psi radiator cap should be used on a lt1?
Old Mar 12, 2008 | 10:56 AM
2000GTP's Avatar
The LT1 uses an 18psi radiator cap.
Old Mar 13, 2008 | 01:47 PM
95camarodude's Avatar
i have the same problem.everything runs awesome, fresh rebuild tranny and motor, but i noticed that my fans wont kick on. i have checked all the relays and fuses and they all check good. any ideas?
