LT1 Miss
Was driving back to school and after about 50 miles my car developed a very bad miss. Under any acceleration on the highway the whole car shakes, idle is very rough also.
At high RPMs it seems to be ok, i have recently replaced Plugs, Wires, Coil, and fuel filter. It is throwing no SES code. It does it when its cold and hot. Opti? any input is great Austin |
ttt
does the idle jump around, maybe a vacuum leak, is WOT ok, or just upper rpms
How do you know it's not logging codes? The SES light doesn't come on for every code. If I where you, I'de scan for codes and also scan for sensor readings. See what's happening in the engine and that may help in pinpointing the problem.
I also don't believe in coinsidence (spelling). Chances are good it is something that was touched recently. Double check everything you did. I'm putting money a burnt wire due to the time it took to occur. Good luck |
It dosent seem to miss at high RPMs, but it could just smooth out enough i dont notice it.
Idle seems steady, but really rough. Current plan is to make it into a garage queen until spring, one wire and plug change was enough... |
Yeah, a wire can easily be burnt, especially with headers. I know about this all too well :o.
Oh, and I dunno about you, but I sure dont take a motor up to high RPMs when I have a miss... not exactly the healthyest thing to do... unless you mean 3000 high. You generally find that a miss will smooth out with higher RPM, but it doesnt mean it is gone. Check it with a scan tool, and check your wires. HTHs. |
| All times are GMT -5. The time now is 08:33 AM. |
