lt1 injector problem
Old Aug 18, 2007 | 09:01 PM
OPies57's Avatar
well i was installing my cam today and i made the mistake of pulling my injector harness's off with out labeling them any way possible to get them right i have a 93 trans am
Old Aug 18, 2007 | 09:27 PM
wrd1972's Avatar
They have numbers screen printed on them.
Old Aug 18, 2007 | 09:36 PM
MR.CLIFFORD's Avatar
agreed. The connectors should also be laid out pretty close to the correct injectors as well if your numbers are illegible.
Old Aug 18, 2007 | 09:47 PM
It doesn't matter on a 93, and they don't have the numbers. 93 is batch-fire, all the injectors on one bank of the engine are connected to the same pin on the ECM, and fire simultaneously. The numbers were added in 94 because the injection was switched to full sequential, and each injector has its own wire from the PCM.
Alex Barnes
Jan 24, 2015 10:21 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
