LT1 hard starting
Old Jan 25, 2009 | 12:32 PM
crispytoast's Avatar
LT1 hard starting
My friend has a 1997 LT1 fbody and sometimes it starts reallllly hard. It is almost as if the battery is weak or he has to much compression for the starter to handle (which is not the case on a stock motor/starter). Whe have checked voltage on the battery and found it to be right at 12vdc then we checked the voltage coming out of the alternator and at idle it was 29vac. I don't know if that is appropriate vac coming out of the alternator or not? If that is correct then what could the issue be?
thanks
-Jesse
Old Jan 25, 2009 | 12:43 PM
maverickmk's Avatar
get the starter tested
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
