LT1 engine swap (computer location)
Old Jan 23, 2022 | 08:18 PM
Cbaird's Avatar
I will be swapping an LT1 out of a 96 Camaro into my 69 Camaro. For those that have tackled this task, what is the best location to place the computer?
I appreciate the info!
Chris
Old Jan 27, 2022 | 12:20 AM
mattdewolfe0227's Avatar
Re: LT1 engine swap (computer location)
Chris
I would continue the swap with a 411 pcm swap and try to mount it somewhere in the engine bay.
Old Feb 1, 2022 | 02:55 PM
Chimera96's Avatar
OP
If using the donor wiring harness & PCM, I would mount the pCM inside theDS fender by making a bracket. If your 69 will no longer need a voltage regulator and horn relay (or move the horn relay) and put windshield washer bottle on the PS inner fender if it isn't already there, you could mount the pCM on the DS core support. IMHO it would look cleaner inside the DS fender
cody96ss
May 9, 2013 12:37 PM
BOZS89IROC
V6 Tech
May 9, 2004 01:46 AM
will69camaro
Classic Engine Tech
Feb 23, 2004 01:13 AM
KwikistZ
3rd Gen / L98 Engine Tech
Nov 6, 2003 10:37 PM
Generalms02
Aug 12, 2003 08:22 PM
