CamaroZ28.Com Message Board
-   -   LT1 Engine Diagrams (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lt1-engine-diagrams-467523/)
00JoeZ28 Aug 20, 2006 09:13 AM
LT1 Engine Diagrams
I'm putting my LT1 back in the car today and was wondering if anyone knew where to find torque specs or vacuum diagrams and possibly a full diagram where all the bolt on's go on the block.
Also I heard that the opti can only go on one way is that true or is their a certain way it goes on. Please help.:D
Dave89IROC Aug 20, 2006 10:18 AM
Re: LT1 Engine Diagrams
look here, lots of info/pics
http://shbox.com/page/index.html
shoebox Aug 20, 2006 11:50 AM
There is only one correct way the opti goes on. It can be installed incorrectly.
00JoeZ28 Aug 20, 2006 03:12 PM
Dave89IROC thank you for that site man very helpful. Found what I needed.:D
00JoeZ28 Aug 20, 2006 03:13 PM
How can it be installed incorrectly if it goes on one way? I 'm lost, can you please explain how the right way to do it. Thanks:D
Lees94Formula Aug 20, 2006 03:21 PM
He means you must line the dowel pin up correctly for it to bolt into place and be flush. You should not have to use excessive force to get it on and there should not be a gap when its on.
