CamaroZ28.Com Message Board
-   -   LT1 engine block (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lt1-engine-block-456035/)
silver95 Jun 14, 2006 11:34 PM
LT1 engine block
I read somewhere that there is a ball bearing in some hole on the engine block. If you take the block to have it cleaned you have to make sure that you don't loose it. Has anybody heard of this? If so, could you please tell me where it is located. Thanks for your help in advance.
396D1SS Jun 14, 2006 11:36 PM
Re: LT1 engine block
there is a ball bearing around the shaft that turns the waterpump
396D1SS Jun 14, 2006 11:39 PM
you have to take off the timing chain cover and there is 2 bolts you have to take out pull the plate and the bearing is right there
xsk5 Jun 15, 2006 12:38 AM
do you mean the steel ball out of the oil gallery?
silver95 Jun 15, 2006 11:41 AM
I am not for sure where it is located. I remember something about it is hard to take out but if you have your engine block cleaned in a hot vat then it is possible to loose it.
xsk5 Jun 15, 2006 01:11 PM
insert a brass drift (i think steel is ok too) into the oil pressure sender hole and tap the steel ball out. it'll drop out of the rear main cap mounting area. the ball itself is .473" in diameter.
shoebox Jun 15, 2006 03:33 PM
Some odd info in this thread. That ball is, indeed, in the back of the engine like xsk5 said.
white97T/A Jun 15, 2006 04:24 PM
what is this "ball" for?
Mike96z Jun 15, 2006 05:05 PM
Sends oil pressure info to your sensor. Had mine dipped and it seems to still be there, running 70 PSI on Melling HV Pump, I wouldn't worry about it.
Kevin Blown 95 TA Jun 15, 2006 05:16 PM
the ball bearing is a plug that makes the oil go to the right place - it is needed cause they needed to drill a hole straight thru, but wanted the oil to turn right.
silver95 Jun 15, 2006 11:45 PM
thanks for your replies.
