LT1 engine block
Old Jun 14, 2006 | 11:34 PM
silver95's Avatar
LT1 engine block
I read somewhere that there is a ball bearing in some hole on the engine block. If you take the block to have it cleaned you have to make sure that you don't loose it. Has anybody heard of this? If so, could you please tell me where it is located. Thanks for your help in advance.
Old Jun 14, 2006 | 11:36 PM
396D1SS's Avatar
Re: LT1 engine block
there is a ball bearing around the shaft that turns the waterpump
Old Jun 14, 2006 | 11:39 PM
396D1SS's Avatar
you have to take off the timing chain cover and there is 2 bolts you have to take out pull the plate and the bearing is right there
Old Jun 15, 2006 | 12:38 AM
xsk5's Avatar
do you mean the steel ball out of the oil gallery?
Old Jun 15, 2006 | 11:41 AM
silver95's Avatar
I am not for sure where it is located. I remember something about it is hard to take out but if you have your engine block cleaned in a hot vat then it is possible to loose it.
Old Jun 15, 2006 | 01:11 PM
xsk5's Avatar
insert a brass drift (i think steel is ok too) into the oil pressure sender hole and tap the steel ball out. it'll drop out of the rear main cap mounting area. the ball itself is .473" in diameter.
Old Jun 15, 2006 | 03:33 PM
Some odd info in this thread. That ball is, indeed, in the back of the engine like xsk5 said.
Old Jun 15, 2006 | 04:24 PM
white97T/A's Avatar
what is this "ball" for?
Old Jun 15, 2006 | 05:05 PM
Mike96z's Avatar
Sends oil pressure info to your sensor. Had mine dipped and it seems to still be there, running 70 PSI on Melling HV Pump, I wouldn't worry about it.
Old Jun 15, 2006 | 05:16 PM
Kevin Blown 95 TA's Avatar
the ball bearing is a plug that makes the oil go to the right place - it is needed cause they needed to drill a hole straight thru, but wanted the oil to turn right.
Old Jun 15, 2006 | 11:45 PM
silver95's Avatar
thanks for your replies.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
willismoons
Feb 14, 2015 08:42 PM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
