LT1 edit questions with an already programmed PCM
If you had a car dynotuned and later got LT1 edit (for OBD1) can you make changes with out loseing the settings that are already in the pcm? What all can you do with lt1 edit? You know the changes are never ending.
Thanks Alan
Thanks Alan
If you got tuned by Ed Wright, chances are it'll be pretty tough to tune from it. You can read it, but LT1 Edit will not read it because of how he rearranges his tables.
The easiest thing to do is flash it back to stock and go from there.
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
