CamaroZ28.Com Message Board
-   -   Lt1 distributor (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lt1-distributor-216648/)
lt1g3n Jan 24, 2004 12:31 AM
Lt1 distributor
I have a block from a 96 camaro LT1, and i am going to use optispark , when i looked under the intake, theres a hole where a normal hei distributor would usually go , at least it seemed.. am i able to use a regular distributor ?? Or should i just stick with my Optispark - (ive yet to buy my opti)
Thanks.
97WS6SCharged Jan 24, 2004 12:51 AM
You can drill the manifold to accept a normal SBC distributor, but since the back of the motor sits beneath the firewall on an f body, it's best to stick with the Optispark.
lt1g3n Jan 24, 2004 01:30 AM
cool, thanks, yea ill do that, especially because my harness is for an optispark. :)
dkeers Jan 24, 2004 05:15 AM
If you plan on running the stock computer you need to keep the optispark. The PCM won't supply fuel unless it sees the low res pulse from the opti.
