lt1 build
lt1 build
OK so far I have scorpion 1.6 roller rockers with lt4 valve springs. I'm looking for a good set of valve spring hardware and a nice emissions friendly cam to go with all this. any help and/or advise is highly appreciated
Posted from Camaroz28.com App for Android
Re: lt1 build
Valve springs are a good start
But if that's what were building on the I would go with 180235-12 NA 266/270 213/217 .485/.495 LSA112 108 Hyd. (this spec is with 1.5 rockers if you use 1.6 rockers the springs will be at their max)
Headers will help a lot 1 5/8 but if you have plans to build it up more later then go with the 1 3/4.
If you use headers I would consider a different cam maybe something straight across the board.
C.A.I.
a mail order tune and you're good to go.
C.A.I.
Moshbmx1
Jan 20, 2015 03:27 PM
