LS7 Card MAF
Old Jun 11, 2014 | 08:21 PM
maybe2fast's Avatar
LS7 Card MAF
Is this a possible swap? the PCM only supports 11200hz max. We would have to scale the MAF tables but from what I have read it is a great MAF and is very accurate...might help drivability.
Also I have a lid conversion so I could run a 90mm calibration for the MAF
Old Jun 12, 2014 | 07:15 PM
Kevin Blown 95 TA's Avatar
Re: LS7 Card MAF
It should work just fine. I am doing something similar by adding a card maf to a 4" inlet. You just need to scale it for whatever dia. it is going into and then maybe adjust it a little for a decent fuel trim.
Double aught
Oct 2, 2015 11:29 PM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
